camaro shift kit
Old Aug 6, 2003 | 02:39 AM
curlytop's Avatar
Default camaro shift kit
how much would a shift kit for an 1989 camaro rs with a 305 cost. i am asking because I don't know where to look for one. thanks.
Old Aug 6, 2003 | 05:59 PM
AlkyBurninX's Avatar
That should have the TH-700-R4 tranny in it. I would recommend the Transgo kit. I have one in my C-6 ford. It was around $80, but expect to pay $125-$140 for a kit for an OD tranny.
With the Transgo kit you can install it for auto shifting or full manual. Full manual means you MUST start in 1st then shift it manually. If you put it in OD, you are in 4th gear. Pulling up to a stop sign means you must downshift to first before taking off. Kind of neat but it can be a pain in the *** unless you are only racing.
Check www.summitracing.com or www.jegs.com
Old Aug 8, 2003 | 10:04 PM
curlytop's Avatar
do you think that if i put one in would it bark the tires when it auto shifts into 2nd. because my cousin has a dodge d-100 with a 318 and it will bark 'em when it shifts into 2nd.
Old Aug 8, 2003 | 10:16 PM
quadturbo's Avatar
check ebay.com
but also check sellers feedbacks
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
