what brand battery charger for atv
Old Sep 26, 2003 | 10:31 PM
adamant's Avatar
Default what brand battery charger for atv
what brand battery charger do you recomend for atv?
anthony
Old Sep 27, 2003 | 07:45 PM
Specta's Avatar
Solar.
Old Sep 27, 2003 | 09:02 PM
stubblejumper's Avatar
Battery tender because it charges the battery and then uses a special circuitry to maintain the charge by constantly charging at a very small current.Standard chargers can't charge at very small currents so they cycle on and off at higher currents causing battery life to be shorter.
Old Sep 28, 2003 | 01:07 AM
ftwflh's Avatar
Any brand as long as it will slow charge (2-4amps)
Old Dec 15, 2003 | 05:34 PM
adamant's Avatar
up
Old Dec 17, 2003 | 03:52 AM
Quad4Fun's Avatar
Battery Tender Plus works great........
Good Luck
Old Dec 17, 2003 | 08:10 AM
Dangerous's Avatar
Check with your local hobby shop that deals in R/C cars or planes. They'll have an assortment of battery tenders that will suit your needs perfectly and priced anywhere from $10 to a couple hundred ea. I have a 500 mah. capacity tender that is ideal and cost was about $16.
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Jul 23, 2015 02:21 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
