More Fuel for the "Which Is Faster" Debate!
Originally posted by: reconranger
The DW aritcle was about a desert race team that was trying out different gearing combinations. These are race prepped bikes, and are hardly stock. I don't have it in front of me, but as I recall the bikes topped out in the low 70's??? Anybody got the article??? And, as I recall the Honda had a top speed that was also just a smidge faster.
Stock Hon - 78.9 - 14/38 - 20" tires
Stock Yam - 78.3 - 14/38 - 20" tires
The bikes used in testing the gearing and tires for top speeds both had HMF pipes, but the stock runs were there for comparison.
I'm not saying that either magazine is right or wrong, but there should be some kind of explanation for the difference. Other magazines have tested the 2 450 quads in the low 70's, so there doesnt seem to be a consensus.
Originally posted by: strongtyerYFZ 3 wheels mean less friction and less weight. thats why dirtbikes are fast. with 4 strokes taking over 2 strokes its going to take a while before they get it perfect. ya, they are never going to be the same or as legendary as the old 2 strokes. just look at the yfz compared to something like a warrior. i think you can call that progress. if you look at something like the yfz compared to a 250R stock for stock there is a huge difference. just my opinion tho. not trying to say anyone is wrong. [img]i/expressions/face-icon-small-smile.gif[/img]
KXT 250-B2 Tecate
Frame number ??
Engine number ??
Engine type 2 stroke, Liquid Cooled
Displacement 249 mL
Bore x Stroke 70.0 x 64.9 mm
Compression ratio 9.2 to 1
Compression ??
Transmission speeds 5 speed
Clutch Type Manual
Oil Capacity .85 Qt
Coolant Capacity 1.59 Qt
Carburetion 34mm Mikuni
Starting system Primary kick
Fuel capacity 2.2 Gal
Wheelbase 50.4in
Overall Length 73.6in
Overall Width 1,130 mm
Ground Clearance 4.9in
Seat height 750 mm
Front tire 23 x 9 x 11
Rear tires 20 x 11 x 10
Front suspension Telescopic fork, 9.8in Travel
Rear suspension Uni-Trak, 9.8
Front brake Single disk
Rear brake Single disk
Final drive Chain
Dry weight 284.4 lb
Approx. retail new $2,599.00
Elkaholic
09-06-2015 02:44 PM
