International Trucks.
Old Sep 7, 2005 | 09:08 PM
  #21
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default International Trucks.
Originally posted by: BlackandRedWarrior
Basically the motors in those trucks are what Ford runs in F-250-550. Though it's available in the 650, I'm sure most opt for the Cummins ISB (same motor Dodge uses in the Ram) or Cat 3126B. Works ok on the low end for 26,000lb with a big rear. The big diesel motors don't have much more HP, but the torque numbers are 700-1000 lb/ft.
I know, but when you see a truck that BIG. I think BIG HP/Torque numbers too. Like 425hp and 1100lbs Torque. [img]i/expressions/face-icon-small-smile.gif[/img]
Yes I am greedy, and I want a 10'-12' bed too. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 7, 2005 | 09:52 PM
  #22
extremerider2811's Avatar
this truck has been out for a while now and so has the gmc's simailer model.... i wouldn't mind having either one....
Old Sep 7, 2005 | 09:54 PM
  #23
actually they go up to about 2500 lb/ft torque in the c-16 cat. it has 600 horses and about like 2300 lb/ft or if your talking about fords diesels then your probably right
Old Sep 8, 2005 | 11:41 AM
  #24
KTM Patrol
Former Chinese POW!
Those are the kind of numbers I'd expect in a truck that big.
Old Sep 8, 2005 | 12:47 PM
  #25
User492's Avatar
A big, heavy truck is really what is needed when towing a heavy load. A 1 ton truck like the F350 may actually tow a very heavy load like a back-hoe or tractor, but if you have to stop quickly or if the trailer gets squirrelly you need the heavier truck to stop it. Of course, if you can afford a toy like the CXT, your wallet should give you all the extra weight you need.
Old Sep 8, 2005 | 02:24 PM
  #26
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
Ford doesn't build diesel motors. They purchase them from Internation-Harvestor (yes, the same motor under the CXT hood is under the hood of Ford F-250 through F-650 with the Powerstroke...just the Ford's are tweaked differently.)
Dodge's is a customized Cummins ISB.
GM is about the only one you could almost say is built "in-house" as they own part of Isuzu who makes the Duramax.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Sep 8, 2005 | 02:25 PM
  #27
Air Cooled Rider
That's the kind of motor found in a Class 8 truck (Greater than 36,000lb GVWR). I.e. "big rig".
Old Sep 8, 2005 | 02:30 PM
  #28
Air Cooled Rider
Actually CA law actually has limits on combined weights. Bascially the tow vehicle (either tractor (in a semi-tractor sense), truck, car, etc.) must be able to stop the combined vehicle from particular speeds in particular distances with the trailer's brake system inoperable (in case of a brake line rupture, disconnect, etc). Ford reportedly exceeds their tow ratings by 2000lb while doing this test. I'm sure most states (if not at a Federal level) have this same basic requirement.
Old Sep 8, 2005 | 02:36 PM
  #29
ThrashAndCrash's Avatar
WRONG!!!!!!!!!! Ford has never used the 466E in anything (the CXT engine). They used the 444E(powerstroke) and that new 6.0. Compairing the 2 is like night and day.
Old Sep 8, 2005 | 08:28 PM
  #30
KTM Patrol
Former Chinese POW!
It "looks" like a big rig to me. Should have Big Rig numbers. That and a longer bed too. [img]i/expressions/face-icon-small-smile.gif[/img]
