RAMPS
Old Nov 17, 2000 | 06:58 PM
FURY60's Avatar
WHO MAKES THE BEST LOADING RAMPS. I WOULD APPRECIATE YOUR OPINIONS.
Old Nov 18, 2000 | 01:55 AM
Pensykodiak's Avatar
Fury, I bought the tri-fold steel ramps from Cabela's for $90.00. They're rated to 1500lbs. I believe. So far they've worked very well.
Old Nov 22, 2000 | 11:29 PM
Fixxxer78's Avatar
The Ramp Master
I have two of the arched ones that are 72” long by 12” wide and I love them. They do not bend but they fit perfect under my quad and I can still close the tail gate on my Toyota Tacoma. They are made out of aluminum and are very light. I think they were about $90 each when I bot them last year.
http://www.ramp-master.com
Old Nov 23, 2000 | 12:20 AM
Lurch77's Avatar
I think your local lumber yard makes the best. Get some spruce staging planks, add a set of end caps from Walmart, and your ready to go.
The metal or aluminum ramps are great. They are very stury and pretty much fool proof. But for me, the wood works great. Its about $20 and if someone steals them, oh well.
Old Nov 23, 2000 | 08:57 AM
BadCat's Avatar
Fury60:
I purchased my ramps from Sears Hardware.
They are steel arched and fold in half and rated at 2,000lb capacity. (1,000lbs. each)
I paid $120 for them. They aren't the cheapest around, but they are heavy duty and in my opinion the best and "safest" ramps I've ever used.
Old Nov 23, 2000 | 11:45 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
I agree with lurch. While the aluminum ramps are great, a set of 2x12's with aluminum end caps work well too. End caps run 20-25 $. 2x's will set you back 15 or so. Cut 'em to the size that fits in your truck with the gate up, paint your name on the bottom and you're good to go. Cheep, functional and not pretty enough to steal.
Old Nov 28, 2000 | 05:48 PM
TrailMix's Avatar
I have a Floe tri-fold aluminum ramp which I wouldn't recommend to anyone. It has sharp rails on the sides that cut into the tires.
Old Nov 29, 2000 | 03:50 PM
RatherB4Wheelin's Avatar
I have used both the wood 2x12 and the aluminum arched ramps. I used the 2x12's until I slid off of them two or three times and then I went to the aluminum. The aluminum seem much safer to me.
RatherB4Wheelin'
2001 Honda Rubicon
Warn 2500# Winch
Old Nov 29, 2000 | 04:27 PM
FKNA's Avatar
I'm with Pensy on this one, I favor the tri-fold ramps. No need in worrying about having it lined up just right. They are easy to handle and slide up under the atv nicely once loaded.
kbbgood
Utility ATVs
24
Mar 9, 2016 03:08 PM
Blodg500RX
Oct 17, 2002 01:33 AM
mitchdb
Sep 13, 2001 07:03 PM
Thumbs
ATC 3-Wheelers
12
Aug 10, 2001 10:40 AM
MrElussive
Jan 17, 2001 05:11 PM
