HELP!!! my disc brake froze
Old Dec 11, 2000 | 08:33 AM
girlatvr2's Avatar
Went riding this weekend in good old New England.
My disc rear brake froze up! what can I carry with me that will fix this very annoying problem? this is the 1st time I go out in the cold. BRRRRRRRRRRRRRRR! but it was still fun! Does this happen all the time or just when going thru water? forgive if this question sounds dumb!
Old Dec 11, 2000 | 09:48 AM
juggalo's Avatar
hey bring some lock deicer. that stuff works great.
Old Dec 11, 2000 | 05:16 PM
bowtiepu's Avatar
a fifty cent bottle of dry gas will work too,and its cheap
Old Dec 12, 2000 | 08:26 PM
hunt365@home.com's Avatar
What is dry gas, and where can I buy it, this past weekend my KQ was froze and I ended up destroying the rear axle shaft, a little $200 mistake. The worst part is I can't get it to run on 3 wheels so i can plow, so i have to shovel all 14" of snow here in chicago.
Old Dec 13, 2000 | 09:14 AM
scramdaddy400's Avatar
Use silicon spray and spray it all around the caliper.
But the brakes should'nt be the only thing your worrying about, if you want to give full protecting on your whole machine spray the silicon on EVERYTHING. What it does is it puts a protective layer on what your spraying it on, this will prevent rust, stop lines from cracking, make plastic more resistent to brakage, and protect the more important piece of your machine the electrics.
For a couple bucks a can its the best protection you can buy.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Dec 13, 2000 | 07:25 PM
Farmr123's Avatar
Carry along a bottle of Heet or similar gas line anti-freeze, it works OK & is cheap. It also helps to drag the brakes a little every now and again.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
