Warn winch stopped working
Old Dec 16, 2007 | 02:08 PM
JohnQ29's Avatar
Default Warn winch stopped working
My brand new warn winch just goes "click". It worked for 10 minutes and stopped. Any info out there?
Old Dec 16, 2007 | 02:25 PM
cataway's Avatar
is the click in the motor or is it the solenoid? is there power at the post were it hooks to the motor when the solenoid is engaged ?
Old Dec 16, 2007 | 02:29 PM
JohnQ29's Avatar
the click is at the solenoid.
Not sure about power at the post.
Old Dec 16, 2007 | 02:40 PM
cataway's Avatar
i had the connector bolts get loose once, it let the thing get all cockeyed and bound up . i'm tiring to figure out if your thing could of lost its ground .
Old Dec 16, 2007 | 02:51 PM
JohnQ29's Avatar
My local Kawasaki dealer did the install and did not send the wiring diagram home with my machine. I hear these Warn selenoids can be quirky. I will go follow the ground and power wires to make sure I have good connections.
Old Dec 16, 2007 | 10:37 PM
john1's Avatar
i had the same thing happen,have them replace the solenoid.
Old Dec 21, 2007 | 11:50 PM
JeffinTD's Avatar
Do you have a test light, or better yet a voltage meter?
If so, take a reading at the cables that go from the selenoid to the winch. My guess is that you won't have voltage when you push the in/out buttons, which would confirm that it is the selenoid. Since it clicks, one can assume there is power to the handlebar switch, which is making it to the contactor.
Also, there was a recall on 4 post contactors, but I'd bet yours is too new to be affected.
Old Dec 22, 2007 | 11:35 AM
JohnQ29's Avatar
I ended up following all wiring from the battery to the switch to the selenoid. When the tech ran the wire from the swith to the selenoid, he never zip stripped it to the frame. He had about a foot of excess wire all bunched up above the exhaust pipe. Needlless to say, after the machine warmed up, it melted this bunch into a big glob of wire and plastic. I re-ran it with new and it works fine. Just goes to show, if you want it done right, do it yourself! Thank you everybody for your input!
Old Dec 22, 2007 | 09:28 PM
KINGQUAD450's Avatar
My warn winch quit working today,I wish it was that simple to fix.
Tore it apart and the hex in the stage 2 sun gear stripped out, it is only a little over 3 months old
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
chuck1177
Jun 30, 2015 09:52 AM
May 27, 2015 11:15 AM
