ATV Ramps
ATV Ramps
I use aluminum ramps... I never used to tie them... mostly because at my house the driveway is slanted and if I park my truck flat the tailgate is a mere 1 foot off the ground... I take it easy like Pagerboy
But I was at a riding area a few weeks back and the tailgate was a bit higher than normal due to the terrain and just as I finished getting the rear tires off the ramp it kicked! Thankfully I was fully in the truck... so NEVER AGAIN!
I will now take the extra 5 minutes to tie my ramps!
ATV Ramps
<div class="FTQUOTE"><begin quote>Originally posted by: CraZySteve
I will now take the extra 5 minutes to tie my ramps!</end quote></div>
Mine came with two quick release straps - takes a few seconds to hool up either to the trailer or to the truck.
Jaybee
Jaybee
ATV Ramps
<div class="FTQUOTE"><begin quote>Originally posted by: jaybeecon55
Jaybee</end quote></div>
hehehe.. mine did too.. I just need to find them... I use my ratchet straps -- hence the 5 minutes..
ATV Ramps
<div class="FTQUOTE"><begin quote>Originally posted by: wildwest1011
I recommend a bi fold or tri fold set of ramps. I have seen too many youtube videos of people getting hurt on ramps, and usually they are separate ramps.
Make sure you strap up to your tail gate each time.
Spend at least $100 on them.. don't cheat yourself, its not worth it.</end quote></div>
Agree here 100%........ I prefer a tri-fold because you only need to be in the middle of the ramp.... no need for worry you are not lined up....
