Carb clean after issue. What am i doing?
Hey guys,
Not sure if right topic but, will move if no results.
I'm having a bit of a issue. When it comes to carb cleaning lately I've been letting my bro handle it. I've done my share, he's done more. Strange thing is we've both been have the same issue afterwords. (This is on different machines)
What happens is after the cleaning everything will run and idle much better but, it always acts as if the throttle cable is hanging even though it's not. So when you give a bit of throttle the rpm's stick at that point. Now you can put it in gear and slowly let out the clutch to let the engine pull the rpm's back down and it will stay until you press the throttle again.
I don't know what's causing this. One quad just seemed to fix itself. Others we've pulled the carb back off dismantled it and put back together and things would be okay. What are we doing?
We sprayed all around and re-seated the boots. Didn't make a bit of difference. Maybe this weekend we will get a chance to pull this carb back apart and see what we can find.
