putting on a SEAT COVER
I have a Ceet seat cover for my 250R and want to put it on. I was wondering, how hard is it to get it on there perfectly. I have a staple gun and all I just don't want to get it on there crooked. I want it perfect. Is this something you could simply do on your own?
I put a ceet cover on the banshee....It was not bad....I used 1/4 inch staples from an air powered staple gun...but I see no problems with a regular staple gun working either....
I would start with the front of the seat and work from there back. Stretching as you go. It is recommended that you leave the original cover on... if it is in good enough shape.
RidE, I attempted installing my Cascade seat cover with a standard staple gun and it would not penetrate the plastic. I then tried an electric staple gun and it still would not penetrate. My next attempt was successful.... I took it to an upholstery shop and used his air stapler. If you are lucky, they may let you use their stapler or just do it for you. It only takes 5 minutes. You could also try a picture framing shop and use their stapler.
pairof98s: '98 Banshee, '98 Sport 400
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
