How to polish the plastic
Old Aug 23, 2002 | 07:12 PM
billiebobber's Avatar
Would like to know if any body has good idea on how to remove fine scratches and scuff marks Someone said try tooth paste.Not to sure about that?
Thank.s Billiebobber
Old Aug 24, 2002 | 09:57 AM
jafo216's Avatar
I use pledge furniture polish . I hides alot of fine stuff and really shines up the plastic , plus it repels water and mud makes clean ups much easier . Been using it for years now . dont aplly in the direct hot sun , after spraying it on let it set about 10 min. then rub it off then in a few minutes buff it with a terry cloth towel. I think you will like it . They make polish kits but they are 20.00 . Try the pledge .
Old Aug 29, 2002 | 12:31 PM
jlpier01's Avatar
Jafo,
I agree with your truck comment. I will try the pledge also. My truck may still bring 10,000, but I cannot stand to watch them depreciate the amount of a good quad soon as you drive it off of the lot.
Old Sep 2, 2002 | 11:23 PM
KingQuadTeen's Avatar
What about 600 grit sand paper?
Old Sep 7, 2002 | 09:40 AM
VirginRider's Avatar
wow never thought of wet sanding them out! that I might just have to test out, you know plastic is the same color all the way through! I think is that true?
Old Sep 7, 2002 | 09:52 AM
95wolv's Avatar
Got this from another guy in the forum: Wet sand with 400 grit,then finish with 1000 grit wet sand,this will make the plastic smooth,but will have a white haze on it.To remove the haze use 3M machine polish(I'm sure other types of metal polishes or buffing pastes would work-my quote,not his) using a foam bonnet air or electric buffing pad,the cloth pad will heat up and turn the polish into glue.When the white haze is all gone,wipe off the polish residue, Then wipe down with Turtle Wax 2001,similar to Armorall,leaving liquid on for 10 min. Wipe down with a cloth and hand buff dry,and it will shine like new.
I'm going to try this after my son and I are done riding this fall to rejuvenate the fenders before winter sets in,sounds like it should work good.
Old Sep 7, 2002 | 10:13 AM
well I will try after you do so! That way I know if it works!
Old Sep 10, 2002 | 05:46 PM
98Lakota's Avatar
Pledge
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Brandon400
Sep 5, 2015 08:44 PM
