Cub Cadet 4x4 cv joint help..
Old Nov 23, 2011 | 10:53 AM
blkcloud's Avatar
Default Cub Cadet 4x4 cv joint help..
I have a 2009 Cub 4x4.. the right front outer cv joint fell apart.. the dealer wants to sell me a complete axle for $300.00. Is there a repair kit for this? I found one for the rear but not the front.. thanks!
Old Nov 28, 2011 | 05:52 PM
wargmc's Avatar
did you find a source for these im looking too
Old Sep 23, 2012 | 01:09 PM
wandarabbit's Avatar
Default you cheat
i got the cv joint for the volunter.the bearing cage has a thick and a thin side.the thin side will go in the outer part of the axle it will stop at the edge of where the bearings go in.i used my bench grinder .you grind or sand the cage down till it will go in to the outer part of your axle.i used the iner race that came off my iner axle .put in the new bearings pumped it full of grease.put the axle in put the boot on.instaled it .the cadet is doing ok.sorry for my spelling.i fix things better than i can spell.
Old Sep 25, 2012 | 02:18 PM
wargmc's Avatar
Default cv
i found some from the cvman
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
89Lt250r
Sep 7, 2015 07:53 PM
cdstang
Aug 31, 2015 07:52 AM
toonces
Aug 13, 2015 12:40 PM
