Which race gas to run??
Old May 11, 2000 | 05:27 PM
BansheePete's Avatar
Which of these race fuels is the best: VP Race Fuels(C-12), 76 race fuel(110,114), or Trick Race fuel??
Old May 11, 2000 | 06:03 PM
THEXOTIC1's Avatar
What kind of mods do u have done to your bike. Also who did your port and polish work they can tell you what to run in your bike. If you just have stock heads and cylinders i would not reccommend race fuel. I have a TC405ex and i run vp 114 if i were to run regular gas in the bike(which i wont) the motor would pre ignite the gas before it needs to and the bike would nt run properly
Old May 11, 2000 | 06:05 PM
Backcountry's Avatar
I prefer VP C-12, then Unocal 76 110 Octane.
Old May 11, 2000 | 11:30 PM
JD250R's Avatar
I run a 50/50 mix of 76 or VP 112 and 92 pump gas.
Old May 16, 2000 | 05:38 AM
Vision's Avatar
race gas is a tottal waist of money if you are not running high compression. rac gas only stops predetination in your bike it will not give you any jbenifts un less you are running highcomp
Old May 17, 2000 | 01:40 PM
KawasakiKid's Avatar
Agreed, racing fuel or high-octane fuel in general for that matter should only be used with high compression engines.
For example, for muscle cars, you can generally run 10.5:1 on pump gas (93 octane) But, if I were trying to run a higher timing on my engine it would start to spark knock or predetonate (very bad, you could burn a hole in the piston). To be running 110-114 octane you should have at least 12:1 or higher for a comp ratio.
Using a compression checker 120psi is around 8.5:1
So, 12:1 should be around 160+ psi easy.
Regarding which brand, I like 76, it's all a matter of preference, bike, and engine. Run what you feel is best.
Old May 18, 2000 | 12:09 AM
fish_bulb's Avatar
There is a complete list of racing fuels with a dyno sheet on how much HP and Torque you'll gain with each on:
http://communities.msn.com/atv
Old May 18, 2000 | 10:14 AM
Lasher's Avatar
Has anyone run Turbo Blue?
I checked out the web site, and did not see it listed there. Back in my race car days, Turbo Blue was the fuel that we ran. It smelled great, but I was wondering if anyone used it in their quads?
I know a supplier for this fuel, that is why I asked.
I have heard that VP fuel is made more for bike motors, is this true?
Old May 18, 2000 | 03:26 PM
Sorry, haven't heard of Turbo Blue. Actually I'm kinda worried that you enjoy the smell so much! LOL
In my opinion engines are engines, fuel shouldn't matter unless we're talking performance (cams, comp ratio, etc.) then it's just a matter of octane.
I believe pump fuel is much like Standard motor oil...Valvoline, Quaker, Kendall, it's all the same to me, yet each of us have our preference or "comfort level" with which one we like. I say try it and if you don't like it, try something else!
It's not going to kill ya.
Later,
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
