You get your power from your stator , becarfull and read your manual and see how much power it puts out , if you put a light that is to powerful for the stator , you will burn it out or need a stator rewind. hope this helps you.
right down by the gear shifter it comes out down where the sprocket is
make sure to use a fuse that is the right size
i had two fog lights on mine but used a fuse that was to large and just blew them both
that pissed me off
