best, chep engine mod
Old Oct 6, 2003 | 04:58 PM
dsheola's Avatar
Default best, chep engine mod
A bigger carb will just flood the motor and will decrease your power unless you put on an exhaust and bore it to a 440 and take your time jetting it so you don't get a case of the honda hicup which occurs when your over jetted or under jetted
also if you buy a 12:1 440 piston and rings and have you cylinder professionally bored you will notice the power, but you will need to run higher octane gas. I run airplane gas.. about 2.20 a gallon and around 100+ octane... be carefull tho with airplane gas.. it almost changes you jetting and you might have to drop you main jet down a little
Old Oct 7, 2003 | 12:13 AM
CroBiker's Avatar
i need somethin that will run off of pump gas. i run premium (91 octane) and i could buy some octane boost if i needed to, but i don't want to have to worry about gettin special gas.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
