NOS
Old Nov 21, 2003 | 01:56 PM
draggincannibal's Avatar
Default NOS
The boondocker system sprays in the airbox or infront of the carb (if you don't have an airbox). This makes sure that no pure nitrous, i.e. nitrous that hasn't been dissolved in the air/fuel mix, doesn't hit the internals. It also makes it reliable in the sense that you can't spray nitrous in if the throttle isn't open. If you want to know check boondockers.com. The site has pics of different applications that they have done and also the article on the boondocker predator that was featured in Dirtwheels. I think it was from august. As for calling Nitrous Oxide, 'NOS', do what you want, it's all the same thing and people know what your referring to.
Old Nov 22, 2003 | 08:25 PM
ZBlaster's Avatar
Default NOS
Originally posted by: REVOLVER
Do you mean N20 or just NOS (Nitrous Oxide Systems, I believe made by Holley)?
Correct.
Old Nov 26, 2003 | 10:43 AM
50021's Avatar
Default NOS
My friend put a boon docker system in his 300 ex and melted his block because he is an idot, becareful if you do decide to put nitro in it because your reliability factor falls and you also run the risk of melting your motor
But it does make huge power increases
good luck
Predator 03 pure polaris nerf bars
Old Dec 21, 2003 | 08:52 PM
Buzzer's Avatar
Default NOS
thanks for the heads up!
