OIL LEAKING OUT OF ENGINE!!!!!
LATLEY I'VE BEEN NOTICING OIL OOZING IT'S WAY OUT OF THE ENINGE. IT LEAKS OUT JUST ABOVE THE SPARK-PLUG AND THEIRS A RING OF OIL ALL AROUND THE ENGINE ...IT MUST BE WHERE THE 2 ENGINE PIECES COME TOGETHER. WHAT'S WRONG???
(THIS HONDA QUAD I HAVE HAS BEEN RUNNING FINE AND NOTHING WRONG WITH THE ENGINE, NOW THIS!!!???)
I can't seem to find any bolts to tighten... their probably way at the top of the engine so I can't see them....now I have to take the front fenders off to see above the engine...
MORE FUN AND GAMES!!!
On the 200, the bolts on the very top of the engine only hold the top cover on, they don't go all the way down into the cylinder -- so if the leaking is coming out around between the head and the cylinder, tightening these won't help -- You would have to take the cover off and tighten the studs from inside the head.
If the leak is between the cover and the head, then tightening the top cover bolts will help. Check torque specifications and follow them. Over-torquing something will just stretch the bolts and the threads and cause them to loosen even more quickly.
Hope this helps
Hope this helps
KimSJoh
14
Jul 18, 2015 07:20 PM
