blaster engine
Old Mar 29, 2004 | 04:46 PM
sandblaster360's Avatar
Default blaster engine
I have a blaster engine laying around and dont know what to do with it.
I dont want to sell it.
can any body think of a small quad frame I could put it in for my sister. she's 8 years old and used to ride my blaster when it had the origanal engine in it.
if any body has any ideas for a project that would be great.
thanx.
Old Mar 29, 2004 | 04:56 PM
Shav0's Avatar
what engin do you have in your blaster now?
i am in the process of putting a IT490 in mine.
Old Mar 29, 2004 | 05:06 PM
dam I was looking for one of those(490) I heard they bolt right up to the blaster frame. couldn't find one.
I have a old kawi 350 single cylinder engine thats been bored to a 360 in mine.
well I'm in the proccess.
I have to figure out the wiring and fab a pipe.
Old Mar 29, 2004 | 07:56 PM
Shav0's Avatar
I think i have got my hands on one. Im more concerned about where to find a carburator and how to make it all work with the air box. I think that the stock air box is way to restricted so I am either going to remove the lid and try and find a carb adapter to hook up the stock air box, or get a aftermarket aluminum one designed for a 38mm. If worse comes to worse then I will just run a straight K&N clamp-on.
So far everything seems to be working out alright. The engin that I am going to get needs a new top-end and possiable a connecting rod. Other then that It is in great shape. From what I have gathered the Pipe from a blaster can bolt onto the IT motor but you have to do a little bending when it comes to the scilencer.
I dont plan on having it done until almost the end of summer, maybe even might hold it off until next spring so I can make sure that i have everything I need and that I didnt cut any cornors.
But once she's done, she'll fly[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 30, 2004 | 01:00 AM
mine should be done in 2-3 weeks. I've been working on it for about 4 months.
about that pipe, don't you think it will be a little small for a 490.I mean the expansion chamber
Old Mar 30, 2004 | 08:29 AM
Shav0's Avatar
Thats what im worried about.
I have heard it done before, with a stock blaster pipe. Not sure if it is a good idea however. I have access to a IT490 pipe but doesn't fit into the frame at all. I am going to check it out and compare the two. My blaster pipe has about the same chamber size as the old YZ490's did and the yz and the IT are almost identical.
Old Mar 30, 2004 | 04:33 PM
let me know when you get it runnin.
Old Mar 31, 2004 | 06:34 PM
Shav0's Avatar
will do
Old Sep 20, 2006 | 07:02 PM
CockyCaucasian82's Avatar
I have a blaster frame lying around I bought it off ebay to build my own bike and then just bought a 2000 BLaster insted.If U want to buy it 50.00 plus shipping.The front motor mounts were shaved off I guess he was going to put a bigger engine in it?????GET BACK
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
