Air intake mod.... need advice
Old Jul 21, 2004 | 06:00 PM
DirtForAShirt's Avatar
Default Air intake mod.... need advice
I plan on replacing my stock airbox/filter with a K&N 3" conical filter that will be located in the old airbox location under the gas tank. Now here's where I need some opinions. I was going to trash the stock airbox and just "free air" the K&N filter. Now, even with a precharger on the K&N, is a "free air" type filter going to be too high maintanance (cleaning after every ride)? The quad is mainly driving in loose dirt but might get a water splash here and there.
Thanks in advance for any advice...
Old Jul 22, 2004 | 10:17 AM
Shav0's Avatar
If you ride in wet muddy areas then I wouldn't do it..
Why not just remove the lid?
Old Jul 22, 2004 | 12:56 PM
ZukZilla550's Avatar
Good point I hit a mud hole and the water stalled the motor,in loose sand they work good,just make sure you clean the filter like the direction's tell you and only use the K&N filter cleaner and oil.DO NOT USE AND AIRCOMPRESSOR AND BLOW THE DIRT OUT YOU'LL RUIN THE FILTER.
Old Jul 22, 2004 | 03:01 PM
rolsmojave3's Avatar
i did this on my mojave but i used a UNI and a outerwears that was water proof and i have had no troubles oh and if your crankcase breather goes to the air box get a UNI breather too otherwise crap will go in to your oil
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
