torque stuffer on a wolvey
Old Jul 28, 2004 | 11:30 PM
rsking45's Avatar
Default torque stuffer on a wolvey
I just bought a 04 wolverine and am looking to get alittle more power out of it. What is the easiest thing that I can do to get a little more out of it.
Ganz is the 424 worth the money? how was it to install?
Thanks Rich
Old Jul 29, 2004 | 12:08 AM
Ganz's Avatar
Rich,
For more power I recomend the HMF slip on and a K&N with the proper jetting. It helps a lot.
I think the 424 is the best investment I put on my wolvey. It turns it into a totally different machine it's so much more fun to drive now. It only took me about an hour to install it with basic tools.
Ganz
Old Jul 30, 2004 | 07:08 PM
Ganz's Avatar
Mr Lotus, you've got a PM.
Old Aug 2, 2004 | 11:10 PM
rsking45's Avatar
Ok I installed the warn 424 over the weekend took about 2hrs it does handle differently,i like it but it needs more power.
Ganz you mentioned a slip on hmf, how is a slip on installed? what kind of $$$ are they
Could I get away with just getting th K and N stage 1 power kit?
Anybody have any other ideas?
Any one know anything about DR.D exhaust goood or bad.The reason I ask is I can get a good deal on them through my work.
Rich
Old Aug 8, 2004 | 09:59 PM
  #15
Ganz's Avatar
A slip on is easy to install. You just have to loosen a clamp and 2 bolts on the stock muffler and slide the new one on. I paid $209 for mine from HMF. I'm very pleased with the power increase. I don't know anything about the other pipe you spoke of. Maybe someone else has heard of it. I would do the slip on and the K&N. To get more power you have to get more air and gas in AND you have to get it out.
Ganz
Old Aug 8, 2004 | 10:47 PM
  #16
rsking45's Avatar
Which HMf do I go with? I want to stay as close to the stock as far as sound goes. Will need the spark arrester cause I do ride on state land. Thanks for all the advise
Rich
Old Aug 9, 2004 | 02:50 AM
  #17
Rock777's Avatar
The HMF Ecoseries is the quietest one that HMF makes, but they don't make it for a wolvey. The regular slip on is supposedly very loud too, that is what kept me from getting it. I just put a Supertrapp IDS2 quiet series on with 7 discs and rejetted and it definitely makes a difference in low and mid-range torque, and is not annoyingly loud, definitely a great investment.
Old Aug 9, 2004 | 04:41 AM
  #18
Rock777's Avatar
Ganz, what size are your 489XT's and how do you like them? How are they in mud? I am thinking about getting 24x11x12 on the rear and 24x8x12 up front, but don't know if this will slow the bike down too much.
Old Aug 9, 2004 | 12:39 PM
  #19
Ganz's Avatar
Rock, My XT's are 23-8-12 and 23-10-12. So far I like them. They do pretty well in the mud and have good trail manners. They are far better than the stock tires on a wolvey. I stayed with the stock size because I was concerned about losing low end. They don't weight much more than the stock tires and they are 6ply.
Ganz
Old Aug 11, 2004 | 10:22 PM
  #20
rsking45's Avatar
I installed the quad works power kit today took about an hour I used the 144 jet and set the needle at the 3rd groove and added the k and n filter.Thing runs great definetly more power.The one thing that I did notice is when I shift into 5th gear it bogs down it looses power. The kit instructed to seat the mixture screw and then open 21/2 turns, is the a final adj on this screw that needs to be done after the quad warms up .Any ideas fellas
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
Steeldon
Sep 9, 2015 09:38 AM
