Rear Shock changes and rear end swapping?
Old Aug 23, 2000 | 11:29 AM
rottwolf's Avatar
Hello all. My banshee tends to swap back and forth after coming out of rough stuff. Do I need to loosen the pre-load on the spring or tighten it? How do I do this?
Thanks,
Jason
Old Aug 23, 2000 | 02:01 PM
PamFalcioni's Avatar
Check your bearings and bushings in the swingarm pivot point and the axle first, something loose would be more likely to cause swapping than incorrect preload settings.
Old Aug 23, 2000 | 04:15 PM
r42176's Avatar
This is a common problem on the banshees depending on rider weight. The stock banshee rear shock is set up from the factory for a rider weight greater than 200lbs. It is usually too stiff and doesn't use all the travel especially going through whoops. You can loosen up the pre-load by loosening the locknut above the spring and then reduce the spring tension by loosening the the adjustment directly above the spring. If loosening the pre-load doesn't help then you should get a softer spring and have the valving redone. This should let the shock work more in the bumps and not cause the rear end to bounce around as much.
Jeff
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
