What frame for snowmobile motor?
You dont want to use the ATV clutches on a snowmo motor. they are physically smaller and wont perform as well. That's the glory of snowmo clutches. They have a lower gear ratio so you can gear the bike higher, but they also have more overdrive for a higher top speed.
#15
i ve done this 6 time now 1 in a trx 250r chassis best handlinglanother in a 250x 3cylinder turbo never has ran right. a banshee lots of frame modes and to small of cooling system. the rest ar in trail blazer set ups.
they work the best but handling sucks. you have to make foot peg extensions and a clutch cover, and long swing arms plus 8 or better. it take about 12 hours from start to finish if you are a half way good welder .
when i get smarter i will post some pictures
250r, 700, atv, banshee, chassis, frame, good, instructios, kind, motor, mount, mountingasnowmobilemotorinaatv, quad, snowmobile, trx
