How do you get rounded bolts off?
Old Oct 11, 2004 | 03:39 PM
MrTommy's Avatar
Default How do you get rounded bolts off?
Ok, I'm trying to replace the rear rack on my 04 Arctic Cat. I got 3 out of 4 bolts off and of course, the last one has pretty much rounded itself (the bold head). I was down to using a torque wrench to loosten all the bolts. Obviously Arctic Cat doesn't give a darn about their own torque specs at the factory. Anyway, now I can't get that last bold out. I applied a little heat with a Bernz-o-matic torch but I have to watch out for the plastic fenders right there. That didn't seem to help. I've tried six sided sockets (broke the one I used! Back to Sears with it). I also broke one socket wrench too. I'm losing patience.
Help, help!
Thanks
Old Oct 11, 2004 | 03:59 PM
hondabuster's Avatar
Someone must have put some thread locker on it, to be that tight.
As long as sears is where you go, they make sockets that go over rounded heads, and get a good bite on the metal, that should do it. You could also try inch based sockets, and see if something works tighter . Like a 3/8 socket will work on a slightly beat up 10 mm bolt head. If it doesnt, then try a chisle and hammer to unscrew, then once its loose it should just come out.
Old Oct 11, 2004 | 04:04 PM
Just4Kicks's Avatar
Oh man, what the heck do they call those things...EZ Outs or something like that? Anyway, I have a set and it has saved me on a few occasions such as this. You might get a set and try it out, they come in all different sizes. Good luck.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 11, 2004 | 04:12 PM
MrTommy's Avatar
Thanks guys. I'm headed for Napa Auto for some sort of "Super Tool" (I hope). I hate this stuff! A simple project like replacing the rack turns into a massive money pit thing... I've soaked it in Liquid Wrench. Now we're headed out to Sears (to get the socket and the socket wrench), then Napa.
Next time I won't roll the machine over [img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 11, 2004 | 06:33 PM
Trasher's Avatar
Tap on it a couple of times before you try anything. Then if yopu get it moving, twist it back & forth until it loosens up. Take your time before it breaks off
Old Oct 11, 2004 | 06:35 PM
Trasher's Avatar
If it's not to trashed, use a impact hammer to remove it. You could also grind a straight groove through the middle of it and use a wrench while someone uses a straight screwdriver and try to see if that works
Old Oct 11, 2004 | 07:05 PM
Just4Kicks's Avatar
Sears sells similar items.
http://www.newmantools.com/drillout/how1.htm
Old Oct 12, 2004 | 01:11 AM
MrTommy's Avatar
Thanks guys. I really appreciate all your suggestions. I finally did get it off. Here's what I did. I took all the broken Craftsman stuff back to Sears and they're sending me new stuff (because the dinky little Sears store here in Carson City doesn't sell individual tools - just tool sets). I went to Napa Auto with a good bolt that came out fine. The sales guy matched it to a six-sided 13mm socket (which appears to be made of cast iron!). Cost me just under $8. Went home, put the socket on my 40 year old torque wrench and went to it. I had my wife tap on the end of the torque wrench/socket as I slowly applied pressure - and VIOLA! The bolt finally broke loose. Man, was I happy! Don't know if spraying on half a can of Liquid Wrench helped, but nevertheless, I got it to break loose. Whew!
So now the new rack is installed, the fenders line up the way they 'used' to when it was new, and life is good.
Sure do appreciate all your suggestions. This is why I've quit logging on to any other ATV site. Hope I can repay some of you - some day.
Old Oct 12, 2004 | 02:01 AM
Trasher's Avatar
Good news! Now it's time to pull some wheelies and drag the rack in the dirt. Just testing it out[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 12, 2004 | 03:24 AM
rescuediver's Avatar
MrTommy, Next time, keep all four wheels on the ground[img]i/expressions/face-icon-small-wink.gif[/img] Play it safe out there[img]i/expressions/face-icon-small-smile.gif[/img] On and off road[img]i/expressions/face-icon-small-smile.gif[/img] MD[img]i/expressions/face-icon-small-smile.gif[/img]
