Cleaning Foam Air Filter with Soap and Water???
#21
Thanks Rob4092 for the tip!!
I bought a can of CRC engine degreaser and cleaned 3 of my filters.That stuff is the best.I had my filters like new in about 2 minutes and it didnt leave a residue. I will never use uni filter cleaner again!
#23
GEE WIZ PEOPLE-NEVER EVER USE A HIGH FLASHPOINT SOLVENT ON A FILTER(GAS,KEROSINE,ETC)IT WILL EAT THE GLUE THAT BONDS THE FOAM TO THE SEALS AND IT DETERIATES THE FOAM AND DRIES OUT THE RUBBER.USE SOAP AND WATER OR A FOAM FILTER CLEANER-YOUR CLEANING OUT THE DIRT, NOT THE OIL SO SOAP WORKS FINE . LET IT DRY GOOD TOO
#24
Everything I've read about foam filters agrees with HRC4EVER to use soap and water and not solvent. The surfactants in detergent helps get the dirt out because it surrounds the particles and stops them from settling back down. I don't have a foam filter on my ATV but if I did I'd wash it with dish soap and warm water like I do with my lawn mower and other small engines.
#25
