Stroker or Bore
Old Jan 27, 2005 | 03:26 PM
TBONE31's Avatar
Default Stroker or Bore
Old Jan 27, 2005 | 03:27 PM
TBONE31's Avatar
which should i get a 509 storker kit or a 480 bore kit............which last longer.............which gives me more speed. I know the stroker would give me hella power.........did i mention i have a YFZ 450
Old Jan 27, 2005 | 08:15 PM
moldycheese's Avatar
i dont know which one wil make more power, but i would go with the stroker, cuz if something happens at least u can bore it out instead of puting a new motor
Old Jan 28, 2005 | 05:31 PM
Boxhead's Avatar
I would save the few extra bucks for the stroker kit. That will give you more torque than the bore. When you get the stroker kit they will usually bore it out also, so it's a good idea to make sure they don't bore it too much. Thinner walls in the cylinder can get hazardous with extreme bores.
Old Jan 28, 2005 | 07:44 PM
schonertkyle's Avatar
The stroker kit would give you more bang for your buck but youd have to rebuild your engine fast. The storker kits tear them up so fast. There was a kid on here that stroked his 300 and a few weeks later it wouldnt start. Id prob. bore it out and get a cam or something like taht. And make sure you get it ported really good to, a bore kit without proper porting is preety much pointless.
Old Jan 29, 2005 | 05:00 PM
TBONE31's Avatar
Thanks everyone for all of you support......i read in Dirt wheels(not that they no everthing) the same thing that shonner said but wasnt sure if that was just because the person didnt know what they were doing when they put it in. So i think im going to get a bore kit from http://www.maxpower-engines.com/atv-bb-yamaha.htm which will make it a 480. Then im going to put on a HMF exhaust. So when i get the bore, they will Port and Polish it for me?
Old Jan 30, 2005 | 01:50 AM
DaBeechMan's Avatar
stroke always gives more power. In more cases then not stroking a motor will increase motor life because it deduces rod angle and slows piston speed.
Old Jan 30, 2005 | 08:40 PM
TBONE31's Avatar
dabeech that is one of the hottest quads i have ever seen and thanks for the support
Old Jan 30, 2005 | 09:20 PM
DaBeechMan's Avatar
new ones will come soon. Thanks
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
