my new project
Old Feb 1, 2005 | 12:40 AM
poontain's Avatar
Default my new project
hi am putting a 250 tri-z engine on a 95 warrior frame. my only hold up is the exhaust im gone have to build a custom pipe. does anyone have any 2 stroke pipe pointers.
Old Feb 1, 2005 | 01:33 PM
proraptor's Avatar
Go to www.powerprs.com and have them build you an exhaust. They build many of the name brand exhausts out there.
Old Feb 3, 2005 | 02:55 PM
DLRPLATE's Avatar
From what I know and tried you can cut any pipe and re weld it to fit any area as long as you dont change the volume area in the fat part . The neck that comes off the exhaust port changes distances you are trying to run. On my drag sled we lengthen or shorten the neck for different distances( builds power low end short power big end long). Maybe that will help.
Old Feb 3, 2005 | 02:56 PM
DLRPLATE's Avatar
basically buy a pipe for that motor and cut it to fit your application.
Old Feb 3, 2005 | 08:13 PM
poontain's Avatar
thanks i got the stock tri-z pipe i guess i will just hack it up and make it fit.
Old Feb 4, 2005 | 11:27 AM
Duneaddict's Avatar
I'd really be careful doing this.... only a 5mm change in length made a huge difference when I was tinkering with building my own handmade pipe..
In a two stroke, pipe tuning has a huge influence in how they run..
My $.02
Old Feb 4, 2005 | 01:02 PM
DLRPLATE's Avatar
I put a ZR 580 motor in my golf cart and had to cut the pipes to make it fit. Like I said do not change the volume. We cut it up a bunch and actually redirected it out the back. Runs great no performance problems not that you would notice being you cant open it up!
Old Feb 4, 2005 | 03:41 PM
Duneaddict's Avatar
Keep in mind that every cut makes the volume a little bit smaller... 10-15 cuts can make a pretty significant difference.
Old Feb 8, 2005 | 04:20 PM
FTG's Avatar
FTG
This is a good topic, since I have toyed with the idea of puting a LT500R of Banshee motor in my Tecate (I would want inframe pipes not drag pipes). Does anyone know any good custom oneoff pipe builders near Michigan?
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Kaleb_00
Jun 1, 2016 09:15 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
Jul 30, 2015 09:39 AM
Sandman2.0
Jul 21, 2015 09:03 AM
