gs1100 motor into a ds650 help!
im going to put a gs1100 motor into a ds650, and i will sure apreciate all the help you can give me, like if i need to modify my frame, make it stronger, changing the shocks, what should i do. i'm gonna have to cut the frame in the front by the radiator, to be able to fit the motor.
any help you can give me will be cool
now i've decided im going to put a newer motor into my ds, but i started the gs 1100, into a suzuki 230 i cut the frame, and put the frame of the bike were the motor mounts, so not too many mods. hopefully i'll have it done by the 21st, were going to the dunes.
I put a kz650 in my suzuki lt500- the exhaust system is tough on a 4 cylinder but the suspension was fine I just had to adjust the preload a little. I did a little gusseting on the frame and avoided any "mid-run welds" in other words I ran new tube from gusset to gusset instead of welding a piece into the frame. no probs and I ride it hard
mrtidy
02-03-2016 05:00 PM
