brand new 05 LTZ400, need a suggestion
Old May 22, 2005 | 01:56 PM
TJs98GT's Avatar
Default brand new 05 LTZ400, need a suggestion
a few weeks ago i bought a brand new 2005 LTZ 400, white with the blue frame and decals. I love it, the thing is pretty quick, a lot faster than my friends raptor 350's. it is my first quad. The day i brought it home i immediately installed a yoshi pipe(slip on muffler) and went for a ride. I also have a k&n filter lid and it came with 2 jets. I want to install the the filter lid but it runs to lean without the jets installed. Should i use the smaller jet or larger jet the filter came with? also how do i install the jet? i am very mechanically inclined and should have all the tools i need. im just new to working on quads. thanks a lot guys!
Old May 22, 2005 | 08:50 PM
InjuryProne's Avatar
whats your elevation?if you are pretty high up,i would not change it.and you need to pull the carb if you are to do it.easy cheesy
Old May 23, 2005 | 04:58 PM
TJs98GT's Avatar
im almost at sea level, no elevation at all really. i know a jet is needed because i tried it without, doesnt run right, with the exhaust it feels ok but might still need a little more. not sure though.
once the car is removed where are the jets located on these things?
Old May 24, 2005 | 12:14 AM
should be 4 screws on bottom of carb.remove them,then just look for the jet that looks like the one you got from k&n.change it to the bigger one if you are at sea level.then see how it runs.you may want to move the clip on needle next.just do the main for now.
Old May 24, 2005 | 04:32 PM
TJs98GT's Avatar
ok, i tried to do that but those 4 screws wouldnt wanna come out. they shoulda used bolts as i stripped 2 of the bolt heads with the screwdriver now i have no idea what to do or how to get them out. im definately going to replace those with bolts
Old May 25, 2005 | 02:57 AM
2fun's Avatar
Grab the head of the screws with a pair of vice grips and they will break loose.
Then head down to the bike shop and get yourself some extra screws, cause thats not the last time you are going to strip out one of those screws.
Old May 25, 2005 | 10:46 AM
once you get them out get screws from the hardwear store with an allen head.just make sure you get metric.
Old Jun 11, 2005 | 05:49 PM
dreamMACHINE's Avatar
hey der, i was wonderin if any one knew if the 2005 ltz 400 has a power increase on the 2004? and if the kfx 400 has? and one last thing, does a big bore kit [70cc version] make it faster that a yfz 450 and honda trx 450r? thanks!
Old Jun 13, 2005 | 12:41 PM
powerstroke01's Avatar
Yup. Teh 05s are faster than the 04s..
Ive heard that a bigbore kit does make it faster. But im not positive.
Old Jun 13, 2005 | 03:35 PM
to -powerstroke01- i see that you have a z400, are they nice to ride and most improtantly,are they fast? im after a z400 or a raptor so am a bit stuck realy. an 6ft2 and im still growing, so i need some power to shift me and carrying me is not easy 4 small bikes! does the z have sufficent power to lug me around?
toonces
Oct 19, 2015 02:21 AM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
toonces
Jul 23, 2015 02:21 PM
Chuck188
Jul 17, 2015 02:45 PM
