Work in progress 98Warrior + 04 CBR600rr engine, few questions
More vids, and smaller now too
http://www.geocities.com/jonaddis842...ialstartup.wmv
http://www.geocities.com/jonaddis842...stmovement.wmv
http://www.geocities.com/jonaddis842...cominghome.wmv
That thing sounds sweet. You'll notice on my pictures I had to leave my cluster on too. Did you switch the quad sprocket to the bigger chain that fits the engine? If not plan on it cause you'll need it. Nice job- get ready to hang on!
Originally posted by: jonaddis84
www.geocities.com/jonaddis842003/warrior.html
How nuts do you think I am to go 140+mph on it? Going to be +4/+4 in the rear and widened +3 in the front.
in a field I would say you're nuts because hitting a rock or rut going that fast would mess up your day
on pavement I would say you're nuts because of how unstable even a stock quad is on pavement. the faster you go the more sensitive and twitchy the steering will get, and the easier it will be for you to flip it. I can't imagine the stock brakes on a warrior were designed to work at more than 70 mph either. what kind of tires are you gonna use - I've seen atv tires expand a couple of inches just from going 65 mph, at 140 they might just go flying off the rim. So i'd say the answer to this is: you're crazy as hell if you do this, but given the opportunity, I would go for it too. looks like fun
No, I switched the engine to work with a 520. They sell 520 conversion kits for streetbikes all the way up to hyabusas so I figure the chain is plenty strong enough as long as I get a good one.
#15
Added new pictures and video to the website
#16
Originally posted by: recon99
I would say you would have to be pretty damn crazy. Are you talking about in a field, or on pavement or what.
#17
i am taking on this task as well but with a r6 motor.....what all was needed in means of electrical??.....thanks is the only thing that i have waited on to get some advice from someone who has done the project before.
#18
your welding work is amazing, simply amazing, what did you do for all the parts did you pretty much take a complete running cbr apart and build it into the quad?
SOLOLUCKY
Oct 4, 2024 09:09 PM
