250ex airbox remove?
Old Aug 23, 2005 | 06:11 PM
250exridr's Avatar
Default 250ex airbox remove?
i wanted to know if i took off the airbox lid on my quad, would it do anything for me? good or bad? you can see the mods i already have in my sig
Old Aug 23, 2005 | 07:26 PM
250exridr's Avatar
come on.. no one??
Old Aug 24, 2005 | 12:54 AM
whiteflash1's Avatar
ya, it will help it breath better, which means more power. you may need to rejet though...
Old Aug 24, 2005 | 10:37 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
I wouldn't take it off. I just cut 4 1" holes and added vents. this way it breathes good and still has protection if I cross mud or water. If you take your air box completely off without rejetting you"ll make it run to lean and burn her up.
Old Aug 24, 2005 | 12:46 PM
250exridr's Avatar
good idea. i'll try that
Old Aug 24, 2005 | 12:58 PM
Try these's... http://www.rockymountainatv.com/Prod...v?pid=00005427
I also changed the main jet all the way up to a 112 and it runs great!!
Old Aug 25, 2005 | 09:28 PM
or you could get an EHS racing lid, mine works great............www.ehsracing.com
Old Sep 3, 2005 | 11:27 PM
recon99's Avatar
If you don't ride in mud and cross deep water you could just remove the lid completely and rejet. When I had my recon, which had the same motor as the 250ex, I ran it with the airbox lid off. The stock snorkel on the 250ex and recon has a hole smaller than a quarter for the air to pass through, so removing the lid makes enough difference that you will feel more power and better throttle response, and it gives it a pretty cool sound.
Old Sep 6, 2005 | 01:07 AM
blindside350's Avatar
Removing your airbox will help your top end (more revs= more air...more surface air on the filter=more air allowed into the motor) You could get a PD filter kit and cut the airbox around the intake tube. But don't do that if your going thru much if any water... Just remove the airbox lid get a PD filter kit and that'll do enough.
Old Sep 6, 2005 | 07:20 PM
recon99's Avatar
what would the pro design have to do with removing the airbox? The ex has a clamp on filter from the factory!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
