400ex problem! Help!
Old Oct 22, 2000 | 10:05 PM
coryatver's Avatar
On my 400ex when i pull on my front sprocket the whole countershaft can move in and out a little. Is this normal? If not, what is wrong?
Old Oct 23, 2000 | 04:37 PM
KawasakiKid's Avatar
That would depend on "how much" it's moving? Is it just 1mm or 2? or are we talking about 3 to 5mm? If it moves drastically, there is probably a ring / cir-clip in the inside of the case that holds that shaft into place. Or perhaps a worn bearing. If it shows excessive movement only way to find out for sure is to crack the engine casing open.
You could check the dealer's microfiche to see how it's assembled, to give you an idea before tearing anything apart.
Good luck!
Old Oct 23, 2000 | 04:52 PM
coryatver's Avatar
It moves 1 or 2 mm. Is the countershaft sopposed to have some play? If you have a 400ex could you see if it is tight or loose? I am wondering if this is normal or is something is wrong with mine.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
