Effects of blown base gasket?
Old Nov 7, 2000 | 11:56 PM
rhino99's Avatar
What would an blown base gasket effect on an 86250r? Mine has been smoking really badly, and when I took it apart I think maybe the base gasket was blown, but it could have been from me taking it off.
Old Nov 8, 2000 | 01:02 AM
retro's Avatar
A blown base gasket would cause the engine to suck in air, causing a more lean condition. You might see a little fuel/oil that is seeping out of the gasket area. I had this happen on my 82 ATC250R.
You can take a punch and make a small dent in the cases or cylinder on both left and right sides. This will pinch/grip the gasket better.
ERIC
Old Nov 8, 2000 | 01:20 AM
brokemybanshee's Avatar
Id fix it, should only take you an hr or two and $20-30. Buddie has a cr500 that had a leak in the base gasket, one day it blew out and locked up on him in 5th... 5th on a cr500 is screaming...
Old Nov 8, 2000 | 04:41 AM
PHATTYBOY's Avatar
BLOWN BASE GASKET WILL ONLY MAKE YOUR BIKE RUN LEANER...YOURS IS RICH...BASE GASKET WAS FINE
Old Nov 8, 2000 | 03:09 PM
rhino99's Avatar
Ok, thanks for the help. I didnt figure that my problem could be that simple, but there is always hope =)
Anyway, I ordered 2 new base gaskets, under the impression that running 2 will bump up compression. Is this correct? Thanks
Old Nov 8, 2000 | 07:03 PM
PHATTYBOY's Avatar
RUNNING 2 BASE GASKETS IS NOT THE ANSWER TO COMPRESSION...THIS WILL CHANGE ALL OF YOUR PORT
TIMING AND UNLESS YOU ARE WELL INFORMED ON MOTOR
MODIFACATIONS YOU CAN SCREW THANGS YOU ROYALY.....
STICK WITH STOCK!!!
EIF
Apr 20, 2017 07:15 PM
kodiacrunner
Oct 4, 2015 11:52 AM
tysonbully
Sep 28, 2015 02:30 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
