blaster mods
Old Nov 13, 2000 | 07:49 PM
badtoy's Avatar
what are some cheap or inexpensive ways to increase a blasters speed or acceleration. thanks
Old Nov 13, 2000 | 08:08 PM
Blastermon's Avatar
Well probably the cheapest way to increase your speed is either going up a sproket size in the front which would be equal to going DOWN 3 sizes in the back. The bad thing about this is that it affects your acceleration.
Old Nov 13, 2000 | 09:01 PM
mxracer27's Avatar
pipe and silencer
Old Nov 19, 2000 | 12:34 AM
WarriorSki's Avatar
Recently added the following to my son's (age 13) 2000 Blaster: Pro Circuit pipe and silencer, Boyesen rad valve, K & N filter, AMP Link. This is now a "bad motoscooter". Next step is adding Vito's powerstroke piston.
Old Nov 19, 2000 | 12:47 AM
brokemybanshee's Avatar
I just got some boyesen reeds and it made a huge diffrence, and only like $25. Alot smoother and just wants to go,go,go..
Old Nov 19, 2000 | 09:30 PM
pickit's Avatar
reeds-pipe/silencer&vito piston with degree key&youll fly
Old Nov 20, 2000 | 05:54 PM
philzie's Avatar
Clean the quad (very clean!). Remove the cylinder head, following the shop manual directions. Take it to a machine shop you trust and get .020 inch milled off the gasket surface. Reinstall with new gasket. Check jetting.
Increased compression gives more power. My wifes still runs fine with 93 pump gas.
Blaster page
Old Nov 21, 2000 | 09:05 PM
Blaster91's Avatar
I just wanted to know how well the Pro Circuit pipe worked on the Blaster. Does it sound good and is the power gain negociable. Thanks WarriorSki.
Old Nov 22, 2000 | 10:32 AM
WarriorSki's Avatar
With the first mods made of Pro Circuit pipe/ spark arrested silencer and K & N filter, our 2000 Blaster sounded dramatically better and there was a noticeable improvement in performance. Rejetting was not required with these mods. While we chose the Pro Circuit, you can't go wrong with FMF either.
Ahtatu
Sep 28, 2015 12:14 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1ArmBandit
Sep 8, 2015 08:59 PM
