replacing stock air filter
Old Apr 10, 2006 | 08:26 PM
cooner's Avatar
Default replacing stock air filter
I am going to replace my stock air filter on my 2006 vinson.Looking at a moose or k&n.Which one will give me better results.thanks
Old Apr 11, 2006 | 08:29 PM
recon99's Avatar
I choose k&n filters for most conditions because they are easier to clean and re-oil, and they are more idiot-proof when it comes to re-oiling them, because they use red oil on a white element so you can see if you miss a spot, with foam filters the oil is not colored, so it's possible to miss a spot and not know it, allowing dirt to slip past the unoiled section.
Old Apr 12, 2006 | 02:58 AM
SFA's Avatar
SFA
I would run the foam filter. I trust them a lot more then a paper filter and find them very easy to clean and oil. Dunk the filter in some kerosene, or use a foam filter cleaner then spray it with some oil....the stuff I use is dark purple so I can't see how you'd miss a spot. I think it's spectro filter oil.
Cole Hadden
Jun 15, 2025 09:05 AM
lightninboy
May 16, 2021 09:52 PM
Reactant
Jul 16, 2015 10:29 PM
1966F100
Jul 12, 2015 03:08 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
