Boost Bottle??
Old May 8, 2006 | 10:54 PM
shecanread's Avatar
Default Boost Bottle??
ok all i know about "Boost Bottles" are they are for two stokes, thier cheap, and thier supposed to bring power rises, so whats the catch. anyone have details on these things? im extremly curious.
Old May 10, 2006 | 12:43 AM
fixitman69's Avatar
some people don't think boost bottles do anything. I personnaly know that when we put one on my friends 03 he gained some more midrange and quite noticeable bottom end. A boost bottle replaces the stock equalizer hose on the banshees. It equalizes the vaccum between the two cylinders intakes to smooth out your performance. I believe the 250R and most other 2 stroke quads only have 1 cylinder and 1 carb so there is nothing to equalize, therefore a boost bottle is not usefull on them.
Old May 10, 2006 | 10:37 PM
shecanread's Avatar
well i was talking about having one on a blaster... so it doesn't do anything for them?? dang.
Old May 10, 2006 | 11:02 PM
fixitman69's Avatar
The only boost bottles i've seen are made just for the banshees
Old May 11, 2006 | 12:01 AM
RDZ350's Avatar
To me they are a waste.One of my friends had one on his' banshee.One of the pipes actually rubbed a small crack in the boost bottle and caused an air leak and burned it up.Pistons actually had holes in them.I actually took the boost bottle off mine and put back on the stock tube.Just not so bulky.
Old May 15, 2006 | 09:59 PM
gassrx's Avatar
the lengthen the intake sound waves to get resence with the pipe, intake, and carbs, some times it works other times it is a waste , it all depends on port timing. same as a spacer plate.
Old May 23, 2006 | 04:10 PM
BruteForce750's Avatar
save your money and take it to the strip club, you be happier at the end of the day
Old May 29, 2006 | 01:02 AM
midnite's Avatar
The boost bottle works better on single cylinder bikes. In fact, some 1980's yz dirt bikes came stock with a yamaha boost bottle. Some say a shee runs crisper with one, but it has been proven on a dyno by toomey that a boost bottle adds no extra hp, or increases or shifts power lower in the rpms. If a boost bottle really did anything you can bet your *** they would cost $125.
panicmanic
Sep 28, 2015 12:59 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Aug 18, 2015 01:00 AM
toonces
Aug 5, 2015 05:55 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
