Cold Weather Jetting
Old Nov 25, 2000 | 12:28 AM
BansheeX's Avatar
I have a 95' Banshee with T-5s, K+N and Dynojet kit. What size main should I run at about 20 degrees. I have been running 320s and that seems good at around 60 degrees.
Old Nov 25, 2000 | 12:41 AM
DunePilot858's Avatar
check your plugs... I run no airbox lid K&N and outerware with FMF fattys with powercore 2's with only 300 mains. I ride at Glamis and the temps vary from about 35 to 80 in the same day.
Old Nov 26, 2000 | 09:22 PM
Rob4092's Avatar
I have oftened wondered how the outside temperature effects jetting.
What is the norm? The hotter the outside temperature, the larger the jet size (ie: increase amount of fuel), or vice versa?
Old Nov 26, 2000 | 09:38 PM
retro's Avatar
Colder air is more dense. You have to increase jet size to allow more fuel to compensate for more air. You should also think about raising the needle 1 position (lowering clip) and maybe adjusting your air screw.
ERIC
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
