05 kodiak 400 airbox lid
You will need to rejet, because its gonna be much leaner than it was.
You may need a size up on pilot jet, but for sure at least 1/2 turn richer on the mixture screw. Then id start with a main jet 3 sizes bigger than stock ( number is stamped on the jet), and go from there.
Heres a good article on jetting to help guide you thru the symptoms of lean and rich.
Jetting article
Jetting article
