416 Bore
Old Oct 5, 2006 | 09:58 PM
HondaFan2010's Avatar
Default 416 Bore
I just bored my stock 400ex out to a 416 and put a hotcams stage 2 cam in it. I have adjusted the valves when piston was at top dead center to the spacing specs provided by hotcams (.005 intake and .006 exhaust) and I still notice a little ticking when idleing. Does an aftermarket cam make more noise or is something wrong?
Thanks
HondaFan2010
Old Oct 8, 2006 | 01:42 PM
TractorPacker's Avatar
Do you have a balloon?
Default 416 Bore
The cam cam will be alittle louder than a stock one. If it is a tick you should be fine. If it is a tap or knock you need to find it. The tick should be drowned out by revving the quad. If you hear the noise over the revving engine, its probably bad.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
