Can you stil jump w/ wheelspacers or perfex susp widening kit?
I was wondering what you guys think about this way of widening.
http://www.diamondjcustoms.com/new/widening.htm
Do you think this would be safe and would work well? Or would wheel spacers be better.
#15
I flipped my front rims on my 07 LTZ400, the valve cover slightly touches my brake calipers, is this ok or will this damage the calipers or the valve itself? thanks in advance
#19
the valvestem cap hits the caliper by at least 3mm overlap but the base of the valvestem is rubbery (I'm new at ÂTV's, not sure if all of the valve's are like this) and so it's sort of flexible. If i remove the valvestem cap it overlaps by 1mm and still hits the caliper, but that is metal hitting metal so I assumed it would be best to leave caps on. here are some close-up photos I took just to give you an example.
Photo 1
Photo 2
Photo 1
Photo 2
#20
ok forget it lol, I've been talking to my friend that race's a ltr450 superquad modded, and he says all I should is buy some spacers and keep the rims inverted, thus making the quad superwide and stable and solving my valvestem problem, thanks for all your help.
