Warrior Jetting Question
Old Jul 25, 2007 | 05:40 PM
mbogosia's Avatar
Default Warrior Jetting Question
You actually just modify your stock airbox. It is under the seat. You will notice that the front half of the airbox needs to stay because it holds the filter in place. However, the rest of the air box cover can be cut off and it lets more air in. It really helps the engine breathe. Some people buy a kit that allows you to remove the whole cover and the filter is held in place by a clamp.
HMF is the brand of exhaust that Warrior owners seem to like. I just ordered one off ebay for $227. This combined wth the air box mod will make a nice difference. They recommend that you adjust your jetting in your carb after doing these.
Don't worry about being new. I am 28 and this is my first quad so I just learned all this stuff. I enjoy learning about this and really look forward to the day I have a raptor 700.
Old Jul 26, 2007 | 04:53 AM
ibjoey's Avatar
thanks man......... when you say adjusting your jets you mean buying a jet kit right, and if so what kind
Old Jul 26, 2007 | 09:03 AM
mbogosia's Avatar
From what I have read you should just buy a main jet and not a jet kit. Stock, the warrior comes with a 145 main jet. Once you introduce the airbox and exhaust you probably need to be using a 150 or 152. To know exactly which one it is trial and error. After trying the 150 pull the spark plug and inspect. Judging by its condition you will know if you need to go up or down.
Old Jul 26, 2007 | 11:21 AM
UKPaisley's Avatar
Also lift the needle up to allow for more fuel in the mid range as it will run lean on part throttle, I used a Dynojet needle, but the standard is ok , move the clip down two notches.
Do a run with 70% throttle, then hit the kill switch, and inspect the plug.
Old Jul 26, 2007 | 06:16 PM
  #15
mbogosia's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: UKPaisley
Do a run with 70% throttle, then hit the kill switch, and inspect the plug.</end quote></div>
I was wondering about this. I might take my carb off now and get this done so it is ready when my exhaust comes in.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Reactant
Jul 16, 2015 10:29 PM
