How do you take apart a seized in engine?
Old Jan 3, 2001 | 10:16 PM
  #21
letitsnow's Avatar
I have 3 different quads...1 has a Wiseco piston,...one has a JE piston,...The other an Arias piston, and I have never had a piston related problem with any of them.
Old Jan 5, 2001 | 02:21 AM
  #22
URnotRoscoe's Avatar
Stock pistons are the best for reliability. Pro-X also makes a good piston. Wiseco makes an affordable LIGHTWEIGHT piston. That is the primary problem with Wiseco the lightweight means less metal so it heats up quicker (expands) faster than the cylinder (especially in a liquid cooled snowmobile in the winter). Wiseco do break in faster and they are good for racing (most guys that seriously race rebuild their engines often). If you go with the Wiseco just make sure you warm up good before you start screaming so you don't cold sieze.
Old Jan 5, 2001 | 12:29 PM
  #23
Dill's Avatar
ART actually makes Pro-X's pistons for them.
Old Jan 5, 2001 | 09:42 PM
  #24
MX265X's Avatar
when my friend seized his "beater" blaster up we used about a whole can of an amazing stuff called PB Blaster!! thats stuff is awesome!! the next day it turned over so we coverend the gasket in silicon let it dry then the next day dragged it behind the good old polaris xpedition 425 (dads, that thing is unstoppable) and he rode it for the next 5 months like that! never had to touch a thing!
Old Jan 5, 2001 | 10:48 PM
  #25
H300F's Avatar
I run wisecos in my banshee .20 over. I broke in for 10hrs, before i finally pinned it. It is holding up so far. I was told pro-x will need less break in time and dont expand as much. And wiseco was racing and hold up better and are stronger but you have to be careful, make sure it is warmed up properly. I would go with wiseco, that is what I will put in the jet ski.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
