Warrior 350 going turbo
Old Oct 23, 2007 | 04:32 PM
tedsxb's Avatar
Default Warrior 350 going turbo
I have a 2003 warrior 350. Im going to turbo it with a IHI turbo off a 2.2l probe. I think its called a RBH5 or something like that. I can fab up flanges for the exhaust, so thats not an issue, and im not worrying about intercooling it. However, I want to use a blow-through setup, so I know that carb adjustments will be mandatory. Is this possible? Do I have to convert to EFI? Is it hard to convert to EFI? If anyone has any kind of suggestions, feel free to express them.
Old Oct 23, 2007 | 06:25 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Convert to a different frame! That Warrior frame has never handled very well. You make it go super fast, and you better hang on.....
Old Oct 23, 2007 | 06:54 PM
tedsxb's Avatar
I know that the warrior frame geometry isnt the greatest, but buying a new atv is out of the question and i got the turbo for next to nothing and have easy access to anything necessary to plumb it. I jsut want something unique using stuff i already have.
Old Oct 26, 2007 | 02:35 AM
DSNUT's Avatar
I don't think the little warrior motor will be able to spool up that large of a turbo. That turbo is sized for a 2200cc gas motor with 4 cyl. Your motor is 350cc with one cylinder.
Since you got such a good deal on the turbo, i would recommend turning around and selling the unit for a profit.
Old Oct 28, 2007 | 07:47 PM
tedsxb's Avatar
I already hooked up the turbo just to see if it would spool it up, and it seems to spool at around 4k and it puts out around 8psi, which is plenty for me. Im going to use a draw through setup because I really dont want to convert to efi and adjusting the carb to accomodate a blow through is rearly impossible. I already have a good oil feed and i plan on draining it through the breather.
Old Oct 30, 2007 | 01:58 PM
TheStir's Avatar
Started riding ATVs in 1974!
How did you measure the 8psi? Did you simulate the air flow you expect through the engine?
Old Dec 2, 2007 | 09:29 AM
SPORTSMAN70003's Avatar
Setting up a carb up for a blow threw setup is possible. You will need to pressurized the float bowl and make sure it has 2-3psi more than the venturi. I have a blow threw setup with a cv carb and its working great.
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Logan Collins
Sep 5, 2015 08:03 PM
