Best way to check compression on a Banshee engine?
Old Jan 9, 2001 | 11:32 PM
Rob4092's Avatar
I just got a Compression guage today and was wondering what is the best way for checking Banshee engine compression.
I was thinking about removing both spark plugs, installing the guage on one cylinder at a time, putting the transmission into third or fourth gear and then pushing the bike with the clutch out for 20 or 30 feet.
Will this provide a true compression reading on each cylinder?
Is there a better way?
How far apart should I expect the cylinders to be from each other?
Thanks!
Old Jan 10, 2001 | 12:26 AM
NewDSLover's Avatar
What I've always been told was to put it in N, (have the gauge hooked up of course - gas off). Full throttle, and kick over 4 or 5 times. Record this number and follow the same for the other. Now you'll have to call your dealer or find out from some other docs. what the compression should be.
Old Jan 10, 2001 | 08:55 AM
Backcountry's Avatar
I think that this question has been asked before here on another post!!!! ;-)
Pull both plugs, gas off, hold the throttle wide open, kick until the gauge stops climbing, wa-la, that's your reading.
Shouldn't vary more than 5% per side. Which would be ballpark about 10 psi for your application.
Old Jan 10, 2001 | 09:09 AM
Rob4092's Avatar
Probably a stupid follow-up question, but it should be in neutral...right?
Thanks!
Old Jan 10, 2001 | 03:16 PM
sanoduner's Avatar
Yes, in neutral and it may take may than four or five kicks. By the way, are you heading down to Cholla Bay this weekend?
Mike
Old Jan 10, 2001 | 03:31 PM
sanoduner's Avatar
Yes, in neutral and it takes quite a few healthy kicks. By the way, are you heading down to Cholla Bay this weekend?
Mike
Old Jan 10, 2001 | 08:52 PM
NewDSLover's Avatar
If you pull both plug then do you need a split hose from the tester to both cyl.'s. My tester only has one fitting. Please explain further.
Old Jan 10, 2001 | 10:31 PM
Rob4092's Avatar
Mike:
I was down there all last weekend.
It was DEAD! Not one single quad on Comp Hill.
The weather was phenominal however! The best I have ever seen.
Marguerittavilla and Dunas were pretty wild. Spent most of my time there.
Manny's is huge. It has expanded to double it's size. Nobody was there however!
I'm headin' south for the Sand Drags next month. Do you know what the dates are?
Old Jan 11, 2001 | 06:14 PM
You pull the other plug so it is easier to kick over. Repeat the same procedure for the opposite cylinder.
joshuafromny
Jun 22, 2015 05:30 PM
B4NSH333
May 26, 2015 06:55 AM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
JRM
Nov 19, 1999 01:41 PM
