Banshee TOR elimanator, for real
Old Jan 15, 2000 | 01:43 AM
DDC's Avatar
DDC
TOR stands for throttle override system.It is a safety device used to kill the ignition, incase throttle slides would stick open without thumb throttle depressed.The advantage of getting rid of them is.The carb is made of very soft metal,the threads that hold the cap on strip very easily.If cross threaded because of these big bulkie tops.Costing you a carb
Old Jan 15, 2000 | 11:45 PM
kbsizer's Avatar
This is not totally about the TOR system, but does a banshee have a rev limiter, also what is a easy way of adjusting or sycro. the carbs. on a banshee. Also mine seems to idle to low, is there a single screw to adjust the idel of both carbs?
Old Jan 18, 2000 | 04:22 AM
VENOMOUS's Avatar
I got rid of the TORS on mine and it gained a little on top end. It responds better to throttle now and the old TORS did strip my carbs threads so I bought new ones for $100 with the caps and new cable and idle kit. Those things are worthless and just ruin your carbs.
Jeremiah Lucas
1989 Yamaha Banshee
Old Jan 18, 2000 | 09:28 AM
sAyIt_fmf's Avatar
I think the biggest advantage for me...when removing the TORS system...was that now I can more easily remove the carbs for jetting...service, etc. Without removing the gas tank just to take the tops off.
Old Jan 18, 2000 | 05:27 PM
  #15
THEXOTIC1's Avatar
The TOR system was a poor design no other race bikes have this on the carbs i have had nothing but problems with the tor system on 2 banshees and a blaster they say it shuts the motor down with the slide sticks not on the blaster the throttle stuck 3 times and off with that POS And the banshee it would not rev as soon as u hit the gas the bike would stall out i cleaned the carbs checked the whole bike over 4 a problem then i knew it was electrical so off with the tos system and the bike ran fine
I think this is the best thing u can do to a banshee so u dont lose ride time over that TOS system
Old Jan 18, 2000 | 07:39 PM
  #16
SaMs0nOLD's Avatar
The carbs on my 87 Banshee have to be rebuilt because the TORS ruined the threads and allowed dirt in the carbs which wore out the slides.
So once you remove the TORS off your beloved Banshee, place the TORS on a hard surface like a concrete floor or rock. Once this is done, grab a sledge hammer and begin to pound with great vigor.
87 Banshee
99 Banshee
Old Jan 18, 2000 | 09:03 PM
  #17
heavosGrandes's Avatar
Thanks for all the input, My TORs have not caused me any probs. and they won't get a chance to, they are gone.
I think I like the last solution the best, and I do have a sledge...
95Banshee
98Warrior
86250R(H)
CosmoM
Sep 21, 2015 04:57 PM
essonlaker
Sep 10, 2015 01:12 PM
black_thunder
Sep 6, 2015 04:41 PM
Slagpolaris
Sep 5, 2015 09:41 PM
