blaster 240
Old May 27, 2008 | 09:46 PM
bigbanshee350's Avatar
Default blaster 240
ok i got a stock 1997 blaster except for a full dg pipe system and vitos airfilter looking to make it faster im looking at the vitos 240 kit and putting a different front sprocket on it along with lowering kit for the front and an extended axle to handle better i dont want to put a bigger carb on it unless i have to o and i already have the oil injection block off kit installed any ideas would help looking to make this thing as bawlsy as i can without spending over 1000$ thanks
Old May 29, 2008 | 06:02 PM
HONDA_ATC_ADDICT's Avatar
Default blaster 240
Here ya go man you helped me on my post i'll help you on yours
http://www.jokersracing.com/co...it_duncan_racing.html
this is the link that will answer all your problems you get this kit and it and your blaster will be ***** to the wall It makes your blaster run with a stock 86 trx 250r down side is it is 1099.00 but if you want your blaster to be the best it can possibly be this is for you.
Old Jun 5, 2008 | 02:34 PM
rayblaster17's Avatar
Default blaster 240
look on projectblaster.com they have alot to choose from they have a regular out of the box 240 kit ot they have their fire breather 240 kit i think it its under 1000 its 9xx something i think but with the fire breather kit i think you need to run race gas and im pretty sure u need a bigger carb for a 240kit which they also have on the site
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
