K&N w/outerwears clamp on style (?)
Going to go ahead and get a K&N filter to replace the pro design prefilter and filter. Now I found this http://www.rockymountainatv.com/wc.d...+On+Air+Filter at rockymountain. Is this the setup with the whole airbox off and the filters hook directly to the carbs?
Right now I have a pro flow alluminum plate to replace the stock version with the box on but the lid off. I want to keep the box on but could run with or without the lid.
Do I need this filter instead http://www.rockymountainatv.com/wc.d...ter+%2D+Yamaha
Thanks in advance.
Thanks in advance.
hey
i have a blaster that i race and i have a K&N on the back and i have to clean it more often than I usually do but i tell you what ti is the best way to go. and you don't have to mess with the banshee air box stuff plus it gives you a lot more room to work around there.plus K&N is the best filter and it would look cool too.
good luck
-Ben #51-
good luck
-Ben #51-
Polaris Side by Sides
Sep 15, 2015 03:33 AM
