CR head Gasket
Old Mar 3, 2001 | 09:59 PM
Kybol's Avatar
I was just wondering if I were to put a CR 250 head gasket in my R, if I would be able to feel the difference
Old Mar 3, 2001 | 10:52 PM
tprender's Avatar
It all depends on what head gasket that you have on the quad now. If you have the metal gasket from the 88-89 you will notice a big difference. If you are using the gasket material one from the 86-87 no, because the are the same or very close to the same as the CR. The reason that people want to put the 86 paper type head gasket on is that it is thinner than the metal gasket. By having a thinner gasket on the head, it decearse's the volume inside the dome. Thus rasing the compression ratio giving you more power. I hope that I used the correct terms.
Old Mar 5, 2001 | 02:47 PM
AIRTIME88's Avatar
Here's the Honda part number for the CR head gasket #12254-KZ-000
AMJ
Old Mar 6, 2001 | 11:23 PM
Adams44's Avatar
I felt a difference on my 88. The Compression went from 170lbs to 192lbs which is just over a 10% gain in compression, also no awful close on running race gas, so I run a mix.
Check your compression first and make sure your cylinder and rings are in good shape. Stock compression will be between 150 lbs and 165 lbs.
You can be a compression gauge at any auto parts store and they have instructions.
If you run a CR headgasket with a Cool Head, you have to put a thin film of sealant on both sides of the gasket or you will have minor coolant leak at the head.
Old Mar 7, 2001 | 06:18 PM
Kybol's Avatar
How would a 85 ATC 250R gasket be, I dont want to be running race gas just pump. My compression is artound 150, rightnow I have a cometic geasket and I think they are thicker than stock even.
Old Mar 9, 2001 | 10:28 AM
Chawness's Avatar
I have found that the CR gaskets do not hold up as well as the ATC gaskets do. If you over heat a little because of muddy conditions, the thin CR wont take it. At least thats been my expirience.
Id go for the ATC gasket if your looking for reliability.
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
