help please.. installing emergency light
Old Jul 21, 2011 | 01:17 AM
pvillefball421's Avatar
Default help please.. installing emergency light
for the winter i would like to hook up my yellow spinning emergency light to the tail of my quad. it plugs into my car through the cigarette lighter, can i splice the wire and wire it to my battery with a fuse? can someone please share ideas to get this project started thank you
Old Oct 23, 2011 | 07:57 PM
polarisbear500's Avatar
yes you can hot wire it that way but it will not shut off if you straight wire it without a switch or splice it in to an ignition wire. What i mean by this is you need to have a switch in between the battery (+) wire and the accessory (light). i am assuming you want to be able to cut it on and off, right?
heres what ya need:
1 x 12volt switch
1 x in-line fuse- use the right size fuse based on amp draw from the light
You will cut the cig. plug off and find which wire is hot (+). that wire will plug into the ACC on the 12 volt switch. then run another wire from the (+) on the battery into the in-line fuse into the 12 volt (+) side of the switch. then you will ground the other wire from the light (-) to the frame or wherever you ground items on your quad. there ya go, should work like a charm. i attached a diagram to help you.
Old Oct 25, 2011 | 10:48 PM
thank you for the answer so i took an external cd player for my computer it had an on/off switch on the back of it can i use it for the switch to wire the light? it says 6a 250v t85 on the back of the switch
JohnnySplat
Aug 6, 2015 12:07 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Sandman2.0
Jul 21, 2015 09:03 AM
