New Sprockets for Blaster
I need to replace the old chain and sprockets on my Blaster, and I'm thinking of changing the sprocket sizes around a bit. I mainly just play around on motocross tracks and freeride so I'm not so much interested in a high top speed as much as really quick acceleration. What are some good choices in sprocket sizes that would give my Blaster more snap but not compromise top speed too much. I run 18" Holeshot MX's on the rear if that matters to anyone. Thanx.
Depending on where you are riding you will probably want a few different sprocket sizes to choose from. If you are on a tight track 14/40 will probably be fine. If you are on a faster,more wide open track you might want to run 14/38 for a little more speed. In most situations the 14/40 will work well.
