Banshee Rear Shock Rebuild
Dale, you could have the Works transplant done. Send your shock to them, they will put a Works heart in it, and Works springs, then valve it to your needs.
Hey, by the way, you think you'd be interested in taking a trip with some of us? We're going to Little Sahara March 14-17, and you're more than welcome to come
Send your shock to C&D Racing. They will rebuild your stock shock with ELKA products and they could even convert it to SSD. I believe their rebuild which includes re-spring, re-valve, re-seal and some other stuff for around $270. http://colbykostman.tripod.com (308)368-7805 that is how to get ahold of them.
Thanks for the info. I will give both a call and see which sounds best. LoneStar I would like to go but thats my anniversary and would not go over well. We some TQRA folks usually make a trip at memorial day. The place is loaded with people and a blast. You should try to make it up then.
Later
Dale
Later
Dale
Scott had is done at works and likes it. He's supposed to be getting a sponsorship and may be buying Axis shocks now though. Be careful at the dunes as usual. There have been several deaths last year up there unfortunately. I think we're going the last weekend in April, to try and beat some of the rush.
